Office 365 Keyboard Problem
Mar 1, 2018
8
So I posted here previously about my keyboard issues. It was typing zeros and periods whenever it wanted. Someone gave me the idea to make a new user for my login on windows. And it worked, no more zeros and periods. Until I installed Office 365. As soon as I installed it, it started again. So I had to make another account on my computer and have been afraid to install Office.
Is there a reason why this is happening? Or has this happened to anyone else?
that was me...
original thread: http://www.tomshardware.com/forum/id-3654522/keyboard-typing-randomly.html
so keyboard works now on a new user? Thing is, Office is installed already, so you you could use it with that user without reinstalling it. Making a new user doesn't remove programs.
I don't understand this, its weird. So Office is the thing that caused it, but why? I would tell Microsoft that story as they were pointing fingers at HP. wonder what office installs that touches input devices.
which model HP is it?
No, in order for me to use Word on this user I have to go into the office 365 program that's pre-installed to install office and install office to use the programs. The only program installed is the OneNote Windows App. So I have no idea why this is happening. The new user wiped everything off the new user - started new, nothing on them. If that makes sense.
I have an HP Envy All in One 24-n014 Touch.
Microsoft doesn't care. So I'm not exactly sure why this happens. But I literally only use OneNote, Word, and PowerPoint, I don't use all the other programs. Like I said, when Office Updated originally, my computer freaked out and opened a bunch of blank Word documents and since then there's been that issue. So I'm assuming it's their update, but I can't find anything about this online anywhere.
did you do this after making new user? - copy contents of C:\users\oldusername onto new user folder.
that gives you access to all the stuff the other user had. I had to swap from my original user last year (approx) and all I did was created a local user, made it admin,. copied the folder details across and set up browsers. Office was there all along.
Look, I would ask a question on https://www.tenforums.com/software-apps/ as they are the place I go to if I can't figure something out myself. They know more about windows than Microsoft seem to and might be able to nut this one out with you.
