Hello everybody and thanks in advance for comments. But this question is different because it's not a brand new build, it's an antique computer. LOL "How old is it?" you ask. Why, the MOBO box says "It's Windows 7 ready" but the manual talks about using Vista 😀.
Anyway, my problem started Thursday night when I broke computer usage Rule #1 -no eating/drinking at your workstation. (I got jelly all over the mouse, ok). After cleaning my hands, I used W10 "shut down" instead of sleep for the first time in months. (possible cause?), then removed and cleaned USB mouse. When I went to plug it back in the same port I needed to lift & tilt the case up on it's front edge to see the port (possible cause #2?).
Hit the power button. DVD player chattered like normal, case fans sped up and lit up, CPU fan came on, GPU fan came on-but no POST beep or display.
Components
Case CoolerMaster 932 HAF
PSU CoolerMaster RS-650-ACAA-A1
MOBO ASUS M4A785TD-V EVO/U3S6
CPU AMD Phenom II 945 Black
RAM 4 GSkills Ripsaws 2 GB DDR3 (2 installed at first build, 2 added in 2018)
Most of those components were assembled in Sept 2010. Which means the PSU is hardwired no plug-in connections. The MOBO only has one diagnostic light (SB_PWR onboard power) and it lights up.
The 2 extra RAM, the Samsung SSD, and EVGA GeForce GTX1050Ti were added in 2018. The free Windows 10 upgrade was done in January 2023.
After removing the side cover I found no dead insects inside, the working power light, and only a loose connection to the front panel audio. Also, moved the display cable from GPU to MOBO connection-no change.
There's a jumper for resetting the CMOS RTC RAM (I think the battery is original) but I'm a little scared about trying that. (Would it work with a dead battery?) Should I try testing the voltage where the 24 wire cable plugs into the MOBO? (Where can I get a wiring diagram?) If the GPU or SSD were bad wouldn't I get the POST beep?
Please post any ideas, suggestions, or things I might be missing.
Components
