I wasn't sure which category this belonged in, cuz I don't know the problem, but I hope someone can please help!
I have a 3 year old 1.2Ghz Athlon with an ABIT KT7A motherboard, 512mb RAM, two internal IDE hds.
Anyway, I powered down my computer a couple hours ago, which I usually don't do (it has been running for a very long time) because I thought I'd give it a chance to 'cool down' or what not, I had to run some errands. I came back home, hit the power button, the computer spins up, lights blink, but then immediately shuts down. Then it will not start again for like five more minutes, where it then does exactly the same things (starts to power up for 2 seconds, turns off and won't go for another 5ish). I unplugged/replugged everything, turned on and off the power strip, got the vacuum out and sucked out the fan of the power supply (without opening, just from behind). When I tried the 2-second power up again, I watched the fans and the both looked to spin fine. Everything else in the room powers up fine, and I have never had this problem before.
Does anyone know what could be wrong? Is the motherboard/cpu dead? Power supply on its way to being dead? It doesn't seem like it would be a mobo/cpu failure because remember it starts, but then I have to wait a few minutes until it will start for 2-seconds again. But I don't know.
Please help! And soon if possible, I have a huge video project for a client that I need to work on as it is due very soon!
Thank you so much!
Danny
Thank you so much!
Danny
