Oil Cooled PC Help
Krenrai
40
I'm attempting to transform my current PC into a mineral oiled PC. I've read into doing it and am going to attempt to make my own solution for it.
However one thing I'm currently debating is whether I'll need to get a pump and radiator immediately.
I plan on having some bubbles in the system which I understand slightly cools the oil and I do eventually plan on having the oil go through a radiator to cool, but currently am unable to afford the solution I want.
Do you guys think that running without the radiator cooling will be okay?
as i said earlier most of the ones i have seen use around 50 litres/11 gallons of oil
since they are all using a pump and radiators i guess 50 litres/11 gallons isnt enough oil to over come the heat being produced
ie--convection cant get rid of the heat fast enough
if you were using a larger tank/case
then it might be possible to not need a pump and radiator
but how much oil/large a tank it would need to do so is beyond my ability to work out
You'll still need some circulation to keep the oil flowing. Without a radiator you'll be relying on convection and the thermal mass of the oil to keep the PC cool. It'll work but prolonged sessions may see the temperature of the oil become a problem as it wont have a great ability to shed heat. It'll also take a long time for the oil to cool after the gaming session.
Edit: how long a "prolonged session" is defined is relative to the performance of the completed PC. It may be a few minutes or a few hours.
i guess you would need a degree in fluid thermodynamics to answer your question
it kind of comes down to
volume of oil
how many watts of heat going into it--and for how long
how much heat escapes through convection
at some point the volume of oil would over come the ability of x amount of watts of heat to where it would stop at a certain temperature and not rise higher
though since i dont have a degree in thermodynamics how high a volume of oil you would need i have no clue
and springing a leak with gallons of oil in there doesnt bear thinking about the mess it would make
I work in IT, and it's just something we've been talking about as being an interesting project. I've been wanting to do it to my personal rig for a while through curiosity as much as anything else.
but thanks for all the replies. I've been trying to figure out a different way of cooling the oil through a separated dry part of the case that I'm planning on making, but do intend to use external radiators at some point.
calling it a project doesnt make it any less of an excercise in futility.it sounds like you know the direction you are going in but havent the resources to do it that way.as was stated you need both a pump and a radiator.unless you have some kind of super computer i cant think of a single reason to go beyond simple air cooling.not dissing you here,i have similar flights of fancy myself.lol
out of curiosity i did some reading
for water but oil will heat up in roughly half the time of water due to density/viscosity
Watts = 3.1 x Gallons x ΔT (in °F) / Heat-Up Time (in hrs)
this assumes 100% efficiency so is worst case scenario since you would be losing heat due to convection
but if you know the heat out put in watts of the components--and say the pc would be on full load for x amount of hours a day
then this would work to tell you how hot the oil would get in a given time--again that would be without heat escaping so wouldnt actually get that hot
obviously this would give a rough guide not an exact one as you dont know how much heat lost or the exact amount of watts being put into the oil
You'd get better cooling if you could increase the the surface area and thermal conductivity of the enclosure. If you are using a glass or acrylic case you could replace the back sides and bottom with a metal sheet and install some large extruded heatsinks (link below) That would help get some of the heat out. For that cost, you'd be better off getting a pump and rad.
https://www.ebay.com/i/172494786862?chn=ps&dispItem=1
