Oil Freezer System.
Jonms94
8
I want to know if it would be possible to have an oil system that would be inside a freezer, I was mulling over the idea of a freezer based system and i knew if you had condensation it would wreck the system
so what if you had an oil system, with the power supply up top or on the side?
Would that work well?
Sounds complicated are you trying for record overclocking ? An oil based system has been done and it works, placing it in a freezer can be diffacult as there will have to be a way to get the power cord and other wires into the freezer. There has to be a good reason to go through wth all this.
I kinda want to with my next build, I am trying to think of a way to get really cold temps, I was thinking Mineral oil or Fluorinert, and about the holes, i have a solution for that, I was thinking normal home insulator with insulating tape layed twice... but i just dont know if the freezer would work well at all
What about Fluorinert?
