Oil Like Substance
Sep 18, 2018
On the bottom of my PC near the front fan there is a oil like substance on the bottom, it certainly smells like oil, would this be a problem.
The computer is around 5-6 month old, it's also no where near any of the main components.
Sorry for the bad images in advance.
http://prntscr.com/kvuy1u
http://prntscr.com/kvuyg1
They seal if off when manufacturing, so there shouldn't be oil outside the bearings' case. I advise you to check the fan
for any oil leaks, and if yes, well then yeah, then the fan might get slower and die from the wear because the lack of oil. You can add oil I think, but it will probably leak out just as badly again.
The front fan as shown in the image above, would it just be excess lubricant they have put on when building it, I've checked the fan and fan speeds and all seem to be working fine, just thinking in the long run.
