[SOLVED] Oily liquid from thermal pads, is it safe?
It's safe. Der8auer mentioned the oil leeching off the pads in one of his overclocking videos. So long as the oily substance isn't discharged from a capacitor(from a PSU mounted above the CPU/GPU, old case layouts) then you're fine.
