[SOLVED] Ok if my car stereo system has 4 speakers hooked up what do I wire the woofer box up to???
Jan 13, 2019
Ok my Kenwood KDC -352U Has front and rear speaker hookup can I still hook up a box woofer speaker to one of the lines like RR or LR.
If your woofer isn't connected to an additional amp, yes you could do that but you might consider using a low-pass filter on that line.
If you want to use an additional amp to power the subwoofer but your radio has no sub output, you can use a line output converter (LOC).
phaelax
377
8
19,015
