Okay here is a a parts list i came up with. i need opinion and help if you think there is a better part let me know.
ChristianJDM
41
So my budget is around 1500-1650 if you can tell me if these parts are good that would help a lot. if you can find cheaper better parts then thats great too. i wanna stick to intel. im gonna use it for gaming and photoshop work. http://pcpartpicker.com/p/35V2H
P.s. will be building by end of month or next month oh and tell me if the monitor is good or if you know better. but keep it cheap as i want to upgrade to a 29" monitor when i get the chance.
Thank you Tom's community!
http://pcpartpicker.com/user/Danbuscus250/saved/3Z5n
CPU Intel Core i7-4770K 3.5GHz Quad-Core $319.99
CPU Cooler Cooler Master Hyper 212 Plus 76.8 CFM Sleeve Bearing $29.98
Motherboard ASRock Z87 Extreme4 ATX LGA1150 $119.99
Memory Corsair Vengeance 16GB (2 x 8GB) DDR3-2133 $203.60
Storage Kingston SSDNow V300 Series 120GB 2.5" SSD $65.99
Seagate Barracuda 1TB 3.5" 7200RPM $54.99
Video Card EVGA GeForce GTX 780 3GB $489.99
Case Thermaltake Commander MS-I Epic Edition (Black/Red) ATX Mid Tower $39.99
Power Supply XFX 650W ATX12V / EPS12V $69.99
Optical Drive Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer $19.98
Monitor AOC i2367Fh 23.0" $156.80
Wireless Network Adapter Asus PCE-N10 802.11b/g/n PCI-Express x1 $10.99
Total: $1582.28...
ok, first of all: unless you will be overclocking, you dont need liquid cooling, 2nd, you dont need a $200 motherboard, you can get one just aas good for $120. 3rd, i would get a 780, not a 770. you will have nough room for it if you take my advice. 4th, that case is way overpriced, $120 is way too much for a case. you can get a case that is perfectly fine for $50-$70. 5th, that psu is WAY overkill. you wont use more than 450watts probly. ill re-design a $1500 pc for you, and see what you guys think.
Unless you're dead set on water cooling (better options as well), a Hyper 212 EVO will cool just fine for ~$30.
I would avoid the Corsair RM series, they still have a few things wrong with them, and need to be worked out. And you'll only need 600W for a single card, you can push SLI with a 750W.
If you stay with Corsair PSUs, I recommend anything from the AX/HX/TX series.
My buddy will be overclocking it a little for me. and i like the case i know i coulda gotten cheaper but i like it im going for a white case and red inside them thats why i picked that motherboard as well. if you can do good performance and cheaper that would be great and if you could actually add some fans too that would be awesome.
Total: $1582.28
has a better cpu, faster ram, better graphics card, better monitor, it has an optical drive and an internal wifi adapter.
ok, the build i did is better performance, and i guess you can decide if you like the case. you can still get the case you had, it will just be a little more money. and for fans, the cases come with them.
with the monitor and the motherboard could connect my ps4 to it as well? and is the kingston ssd better than the samsung evo?
Latest posts
