Old case has on front panel 2 2.0 USB slots, new case has 1 2.0 USB and 3.0 USB slot. Will there be a problem?
romethaug28
112
Hey. i´m upgrading my case, but i noticed that old case has 2 2.0 USB slots and new case has 1 2.0 USB and 1 3.0 USB slots. Will there be a problem?
Old case: https://microdream.co.uk/lenovo-thinkcentre-m91p-sff-quad-core-i5-2400-4gb-250gb-windows-10-professional-64bit-desktop-pc-computer.html#.WloLqdV96po couldnt find better site.
New case:https://arvutitark.ee/est/tootekataloog/0/deepcool-Tesseract-USB-30-x1-USB-20-x1-Mic-x1-Spk-x1-valge-must-Midle-Tower-171065.
I am pretty sure it comes down to the motherboard right?!
MOBO:https://www.amazon.com/ThinkCentre-Desktop-Motherboard-03T8351-IS6XM/dp/B0188ZJX8I
Thank you for your help!
drea.drechsler
Respectable
Oct 16, 2017
1,052
31
1,840
188
The case should provide one cable for the USB2.0 'slot' and one for the USB3.0 'slot'. If the motherboard doesn't have a USB3.0 header to connect the cable to all you'll have is a non-functional USB 3 slot on the front panel.
The only problem I see is that you'll have only one functioning USB port on the front now.
Strange.. Usually, front panel ports come in pairs.
There are a number of add in motherboard adapters that will give you usb3.1 capability.
Some will have internal connectors, and some will have rear panel outputs, often both.
They can go in the x1 pcie slot, or the pci slots.
It all depends on what you need.
Then, also, you can buy front panel devices with various usb and sdcard ports.
romethaug28
112
Ok, that sucks. i thought this case was perfect for me... guess i keep looking for a case with 2 USB 2.0 slots.
Thank you!
romethaug28
112
ok, thank you!
i found this case: https://www.1a.ee/arvutikomponendid_vorgutooted/korpused_jahutid/arvuti_korpused/ibox_force_1810_atx_black_of1810usbaud. This has 2 USB 2.0 slots. But will the geforce GTX 1050 ti will fit in that?
romethaug28
112
Sad, thank you!
Similar threads
