News Old HDD modded into a variable speed disc sander
Some hard drives use glass platters. Imagine what might happen if a platter breaks at 7,200RPM. Even more "fun" at 10,000 or 15,000RPM. Face mask anyone?
iu
iu
Its fine, totally fine, see it has the sand paper that was attached to the top, its like extra reinforcement, or something lol.
A 30 Amp ESC? Are you sure? My car charger is hooked up to a 30 Amp circuit. That's a huge amount of current !
Thats what i was thinking, thats a ton of power for such a small motor. I mean i guess if its what you have on hand, still seems like overkill though.
30 Amps at the low voltage side, not the AC side. 6.6kW would make that explode, instantly.
So like, maybe 100W to the motor at 3.3V? Still high, not sure what voltage the spindle runs at.
Also, they gave that for the controller's power rating, not necessarily what was sent to the motor.
Reactions: bolweval
Guys, the ESC is capable of delivering 30A (peak, burst), that's it. The actual current draw will likely be what it was before this thing became a questionable power tool, depending on the voltage used and the mechanical load from "grinding".
I would be happy to run this at, like, 10k rpm or lower, with a shield around the edge to catch the exploded platter.
I know enough about this by experimenting with something like this a long time ago. Turns out, when you apply pressure to a spinning drive platter (at 50-70k RPM), it can unexpectedly explode with enough force for the shrapnel to pierce 16ga sheet steel.
Latest posts
