Like the thread says I just bought an elite level monitor. One of the big selling points for me is the 240z (also 1ms) which it's advertised as having. When I used the mouse on the new monitor i noticed a bit of what seemed like lag; it just seemed a bit slower. Which, as you know, is bad for gaming. I wasn't sure if it was the response time of the hz so I checked the display settings, went into advanced display settings and there wasn't any setting above 144hz so I knew it was the hz. This is quite troubling because I'm using the same HDMI cable that run at 240hz on my old monitor. I tried with a 2.1 HDMI cable (which by the way aren't functional because they're too short) and same deal: only 144hz max. If anyone could share some light on this situation that would be greatly appreciated. Have I been duped(BTW I bought this monitor from a reputable company)? Is there something I haven't done that I could do to make it run at 240hz?
Here is a link to the display specs for the new monitor: https://www.displayspecifications.com/en/model/128c1f95.
Many thanks.
Many thanks.
