If you don't have a power button, you can use a screw driver to short the +ve and -ve pins on the motherboard's front panel pins...but before you do so, I'd ask you to mention the specs to your build to prevent you from ending up with a house fire(for lack of a better scenario description). Please list the specs to you build like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
CPU:i3 10100f
Motherboardrime h510me
Ram:16gb ram ddr4 2666mhz crucial
SSD/HDD:hdd
GPU:gtx 1650
PSU:evga 600w w2 80 plus
Chassis:i dont know what is chassis
OS:windows 10
Its a lenovo thinkcentre and i saw the power cable button i its not 2 but its more holesNot likely to have caused any damage.
Your case should have a front panel power lead that you should connect to the motherboard front panel header.
If you ever used this case before, you should have such a cable.
If no, or it was damaged, you can buy such a power button for not much.
Do you know the make/model of your case?
If not, post a pic.
And no display i hear fans and every thing my keyboard led is on but wont work and my mouse doesnt have lightI dont know if its the hard drive
