I have a normal laptop that works fine for me, but my mom has a really old one (couple years old) and it's running extremely slow in my opinion. It's an Asus EEE pc 1000HD with 1 Gigabyte of RAM (DDR2 SODIMM 667Mhz PC2-5300), Intel Celeron M 353 at 900 Mhz and some integrated graphics card which I don't remember now but it's really bad overall... The thing is, she is doing all those virus scans and defrags almost every day (a bit extreme in my opinion but whatever) with two antivirus programs. Free version of Avast and purchased Advanced System Care...
I disabled some of the graphical settings in Windows XP but that didn't help much, tommorow I plan on going through her files and removing old clutter which the defrag doesn't remove. Other thing which might lag, is that she has about 200 bookmarks in her web browser which may or may not add up to the slow processing of the computer. I cannot upgrade it because she is too scared it will "break" so that's out of the question... I also plan on getting a cooling pad for both of our laptops and I'm not sure if that's going to fix anything or just make things worse.
By the way her system is Windows XP Home... It's past midnight here so sorry if something doesn't make sense, I will check tommorow and reply if needed... Thanks for any help suggested
//After done edit= she doesn't have a battery plugged in because the battery got cooked while we were on a holiday in Greece couple years back so she is just plugging her computer in the supply.
