Good evening,
I've dug out this old machine that has been in the attic for a long time and tried to see if it still works. Upon turning the machine on the PSU will start up and the fan attached will start spinning, but nothing is output to the display and the lights on the front of the machine do not light up. When the machine is turned off using the button on the front of the machine the HDD light will flash once before the PSU goes silent.
So far I've changed out the RAM, plugged in a fan to see if the PSU was defective, it powers the fan so I'd assume it is supplying power to the the motherboard. I've attached 3 photos and I'm hoping that someone would be able to identify the motherboard
. In the 3rd photo I have taken a close up of what I believe to be the problem, it looks like something is missing, I'm also hoping someone can identify which board it is and hope it's fixable.
I have tried to work out which motherboard was in the machine but currently have no idea,
This is the part I believe is causing the issue, it looks like something is missing within the circles and there is some bent metal there as if something has been pulled off. (I hope I'm wrong in this assumption or that it can be rectified)
Any help would be greatly appreciated
