So over the past half a year or so my pc has been randomly crashing every now and then, first it started with just freezing while playing games, didnt get a BSOD but still had to hard restart the computer. However like 2 months ago my pc started randomly freezing and crashing into BSOD even while watching youtube vidoes and most of the time it would crash instantly into BSOD on restart at least once. I also had a weird sound loop every time it happened.
Most threads said it was driver issue so i tried installing the newest nvidia drivers and even rolling back to some old ones but it didnt help. So i ended up completely resetting PC to factory settings about 15 days ago and that seemed to work - or at least for a bit. Today i got the same crash(freeze + sound loop -> bsod) around 3 times, first in a game, then on startup and then while watching a twitchtv stream. After the third crash my PC didnt even want to boot so the only option was to reset my PC from safe mode once again and it booted normally (that was around 5 hrs ago and didnt crash since)
I am not really looking to fix my PC since its old and i got a whole new PC except for the graphics card because they are impossible to get at normal prices i can afford so what im trying to do is eliminate my GPU as the failing component so i can build my new PC without worrying its gonna start crashing again.
Is there any way to make sure the GPU is 100% not at fault without trying it in a different PC since i dont have one.
I already tried running FurMark for about 30 minutes, temp didnt go above 77C and i didnt see any graphical errors but as i said nothing was happening the past 2 weeks either so i cant really be sure.
The GPU is around 3.5 yrs old while the rest of the components are almost 6.
CPU : i5-6500 3,2ghz
GPU : GTX 1060 6GB
MB : ASRock B150M Pro4S
8GB RAM
GPU : GTX 1060 6GB
8GB RAM
