Uh.... 750Ti is left wanting when compared to a 1050. To use any GPU that pulls more than 75W will require said PSU (unknown brand and model) to have PCIe power connectors, which since we have no other info than wattage, it may or may not lack (since we can't see it.) The OP would have to verify that themselves before dedicating the resources. Also the original GPUcard in the unit is a workstation ATI FirePro v4800, The R9-280X wouldn't fit in the PCIe16 slot due to length restrictions. If you looked at the linked document, you would also note there are only two PCIe slots that are greater than one lane... a 16 lane and a 4 lane. no 8-lane slot exists. The 1050 can also be had for less than a 750Ti, at least in the States, too.
Tom's own review testing shows the 1050 to beat the 950 and trounce a 750Ti.
Yeah, a SSD will make things snappier, but a 120GB SSD will fill VERY fast, especially if one tosses Office in the mix and a few other apps. Yes if they don't have a lot to load on it, they may have room for one, MAYBE two games, but that would be it... but let's look at the SATA ports for a second... SATA? Yes SATA-I more than likely as I'm sure SATA-II would be noted in the manual. That will also diminish the snappiness. (more info needed to verify SATA standard used with the SATA ports)[/quotemsg]
shrapnel_indie,
Yes, different GPU's have different performance, and in the absence of a budget and given that the system is an obsolete, free system, the upgrade budget is probably minimal, and a used GPU has the best cost /performance.
The GTX 1060 is the best choice in my view: compact and high performance, but it costs 3-4X the value of the whole system. Also, the only previous generation GTX's I know with a compact version that also uses lower power are the GTX 750Ti and only a couple of GTX 950 versions. A used GTX 750Ti can be purchased for as little as $50-$80 while an EVGA compact GTX 950 2GB still costs $120-$150, 2X or 3X the system value. When upgrading, the compatibility / cost / performance equation is not so simple.
If you had read the post, the Celsius x480 has a 500W power supply and common to workstations of that period certainly a card up to 150W is possible. I have a 2011 Dell Precision T3500 with a 525W PSU and Dell relates it to use 2X 150W cards as does the 2015 HP z420 with a 600W PSU. All the workstations I've had of that (Dell Precision 390, T3500, T5400, and T5500 always had at least 6-pin connector, or can use a Molex to 6-pin connector. the T3500. There were T3500's sold with a Quadro 6000 6GB- 220W peak and requiring two connections.
Nowhere is it suggested the w480 has a PCIe x8 slot, only that GPU's may run at x8 without a serious performance loss, but that @ x4 would be noticeable.
The OP says of the new system "
she want's to play World of Warcraft on it" and will understand the drive size requirements. Again, the idea is to minimize costs. Windows 7 is 30GB and WoW requires 45GB, so yes a 120-128GB drive isn't roomy.
According to
the w480 specs there were x480 systems offered with SATAII and SATAIII drives:
SSD SATA, 256 GB, 2.5-inch
SSD SATA, 128 GB, 2.5-inch
HDD SATA III, 10000 rpm, 600 GB, 3.5-inch internal
HDD SATA III, 10000 rpm, 300 GB, 2.5-inch
HDD SATA III, 7200 rpm, 1000 GB, 3.5-inch, business critical
HDD SATA III, 7200 rpm, 500 GB, 3.5-inch, business critical
HDD SATA II, 10000 rpm, 150 GB, 2.5-inch, S.M.A.R.T.
HDD SATA II, 7200 rpm, 2000 GB, 3.5-inch, business critical
HDD SATA II, 7200 rpm, 1000 GB, 3.5-inch, S.M.A.R.T.
HDD SATA II, 7200 rpm, 500 GB, 3.5-inch, S.M.A.R.T.
HDD SATA II, 7200 rpm, 320 GB, 3.5-inch, S.M.A.R.T.
HDD SATA II, 7200 rpm, 250 GB, 3.5-inch, S.M.A.R.T.
HDD SATA II, 7200 rpm, 160 GB, 2.5-inch, S.M.A.R.T
Cheers,
BambiBoom
CAD / 3D Modeling / Graphic Design:
HP z420 (2015) (Rev 3) > Xeon E5-1660 v2 (6-core @ 3.7 / 4.0GHz) / 32GB DDR3 -1866 ECC RAM / Quadro K4200 (4GB) / Samsung SM951 M.2 256GB AHCI + Intel 730 480GB (9SSDSC2BP480G4R5) + Western Digital Black WD1003FZEX 1TB> M-Audio 192 sound card > 600W PSU> > Windows 7 Professional 64-bit > Logitech z2300 2.1 speakers > 2X Dell Ultrasharp U2715H (2560 X 1440)
[ Passmark Rating = 5581 > CPU= 14046 / 2D= 838 / 3D= 4694 / Mem= 2777 / Disk= 11559] [6.12.16]
Analysis / Simulation / Rendering:
HP z620 (2012) (Rev 3) 2X Xeon E5-2690 (8-core @ 2.9 / 3.8GHz) / 64GB DDR3-1600 ECC reg) / Quadro K2200 (4GB) + Tesla M2090 (6GB) / HP Z Turbo Drive (256GB) + Samsung 850 Evo 250GB + Seagate Constellation ES.3 (1TB) / Creative Sound Blaster X-Fi Titanium PCIe sound card / 800W / Windows 7 Professional 64-bit > Logitech z313 2.1 speakers > HP 2711x (27" 1980 X 1080)
[ Passmark System Rating= 5675 / CPU= 22625 / 2D= 815 / 3D = 3580 / Mem = 2522 / Disk = 12640 ] 9.25.16
