1 Pc case has 60mm fan with in flow thru 102 1/8" dia. preforations on each side. ( Note case fan spot is limited to 60mm fan size)
The other pc case has 5"x12" perforated opening near case rear and 4 rows of 1/16 " x 1/4" perforations on each side(near hdd slots). ( The fan size can be increased .)
Neither unit runs hot.
Both unit sit on floor of residence and collect a small amount of dust within 6months clean cycle.
Would the air flow be better if the case fans provide in flow instead of out flow?
Also both psu have 120mm fans providing out flow to the psu exhaust fan.
These are basic pc no gaming.
Thank you.
Thank you.
