OMG So Many Fans
childofthetao
139
Hi, I'm trying to shop for fans but there are so many I don't want to make a bad buy.
I want to replace the fans in my 550D and when I buy a H100i I will probably want to replace those fans too.
The Noctua fans are too expensive but I don't want to buy cheap fans. Wit the case being a 550D and it has sound dampening maybe quietness isn't too important, just performance?
Thanks for the help.
I don't want molex fans, I want them to connect to my motherboard.
What would be good fans to buy to replace the stock H100i fans? Would SP120's do it?
Also I am looking for a 200mm fan to go on the side panel.
Update: I managed to get a cheap H100 so I'm gonna use that. What would be good 120 fans to replace the stock fans with? Noisy fans are fine as the 550D has sound reduction foam.
That's one thing I love about the Obsidian 550D is that it has TONS of places to mount fans.
The top and the side allow for 2-120mm fans or 2-140mm fans, in the front you can mount 2-120mm fans, in the back you can mount 1-120mm fan or 1-140mm fan and on the bottom you can mount 1-120mm fan or 1-140mm fan. That's 8 fan mounting points. None of them allow for use of a 200mm fan.
Also I have a problem determining the size of the side panel fan, almost every site I look at gives me a different number. Does anyone know for sure what the size is of the single side fan mount on the 550D?
