Hello,
I have a MSI Z97 PC Mate. On board there are 2x 4pin CPU headers (only using 1 at the moment), 2x 3-pin system fan headers, and 1x 4-pin system fan header.
Upon further reading, I have found that on the 3-pin headers, the 3rd pin is unused, so the other 2 pins are just steady +12v. So naturally, they don't show up in any software.
And the 4-pin header is really only a 3-pin as the 4th pin is also unused, but apparently is does have the ability to adjust voltage per the tach wire and software like MSI Command center, etc. based on the system/CPU temps. (not a PWM header)
So, what I am trying to do is to take this 4-pin (really 3-pin) header, and control the speed for all case fans simultaneously. However, based on the amp rating, I suppose I can only connect 2 fans to this one header, but I need to control 7.
So is there a solution to being able to use the voltage control from the 4(3) pin header to control 7 fans?
I mean is a DIY sense, what type on electrical device will allow me to take adjusted voltage in, to dictate adjusted voltage out? I mean, I am fairly fluent with relays, but those are simply on/off. Is there a device that can take the variably controlled voltage out of the header, and ramp up voltage to the fans from the PSU?
I am also looking into the NZXT Grid V2, but if i can DIY it, i would rather.
Also, I am open to suggestions for other recommended setups, (not necessarily opposed to using the other CPU header, but would rather not) but I really want to try and stay with auto fan control based on system temps. To me this just makes the most sense. I don't want to have to bother with dials, or touchscreens, etc. Also, I suppose I can use a drive bay type controller, but they are usually not USB tied for control, so i am left with relying on the temp sensors that come with it, rather than the actual board dictating temps.
If I have mis-spoke on any facts, please correct me (still learning)
Thanks in advance,
Thanks in advance,
