onboard audio not working
techmo119
Commendable
Jan 15, 2017
32
-------Please Read My Question Fully Before Answering-------
I'm currenly using a asrock ab350m micro motherboard
I clean installed windows 10 and I tried every possible solution but my audio doesent work
heres a list of things I tried:
-downloaded audio drivers from the cd that came with my motherboard
-downloaded drivers from the internet for my motherboard
-tried manually installing realtek drivers
-updating my bios
-updating my gpu drivers
whenever i go into playback devices it shows 5 different things and they are all called high definition audio device and they all are HDMI jacks even though i dont have any hdmi ports except for 1 on my gpu.
another thing i tried was go into my device manager and go to the amd high definition audio device, and i click update driver then i click "browse computer for driver software" then i click"let me pick a list for available drivers" then i uncheck the box then i uncheck the box that says "show compatible software" because the realtek drivers are not shown ,so then find the realtek drivers and after it is done installing it CRASHES immediately.
i know i have realtek drivers installed as i can see them in my programs in control panel but when i type for realtek in my search bar nothing shows up...im really confused.
is there any fix for this situation or is this just a faulty motherboard?
Did you clean install windows or not? Here, your op says you did but your other thread which was merged here says you didn't.
Conflicting drivers most likely.
In safemode uninstall realtek audio from device manager and then Realtek HD audio manager from programs as well.
Reinstall in normal Windows, audio drivers for Win10 either from cd, Asrock website or from Realtek.com
MERGED QUESTION
Question from techmo119 : "i installed a new motherboard and cpu and now my audio drivers wont work"
i already downloaded from their website and like i said it doesent work
