Onboard realtek or sound blaster pci card
I just built new computer with a GA EP45-UD3lL i was wondering should i stick with my onboard realtek or use my sound blaster audigy 2 platinum PCI card which i already own from a previous build the onboard realtek sounds pretty good only problem is it has a poping noise every once in awhile when the CPU goes under a lil load.
What are the benifits of going with a dedicated card?
The card is pretty old probbaly about 6 or 7 years old is the newer onboard sound better?
I was thinking of just selling it so i can get a better heatsink for my CPU
The Audigy is much better as it has it's own chipset and doesn't make your cpu work for sound... Even if that is no longer a problem since all new cpu's are minimum dual cores.
I would put in the Audigy and disable the onboard sound.
Also I think realtek does a good job overall but isn't all that great next to ADI (the other onboard sound chipset that gets put on the "premium" labeled mobo's
