I have a newly built gaming pc, here are the specs.
3570k @ 4.5Ghz
sabertooth z77
32gb g.skill ripjaws z 1866
ocz vertex 4 128GB x2
Asus Titan PCI Express 3.0 1150MHz
Cooler Master HAF X 942
Cooler Master Silent Pro 1200w
Thermaltake Water 2.0 Extreme 81.3 CFM Liquid CPU Cooler
27" IPS LED CrystalPro Monitor WQHD 2560x1440
My headset is from monoprice
7.1 Dolby Digital Amplified Gaming Headset
http://www.monoprice.com/products/product.asp?c_id=114&cp_id=11403&cs_id=1140304&p_id=9771&seq=1&format=2
I mainly play WOW, and will be getting Metro last light when it releases, and plan to buy other new high quality graphic games, but at the current moment my question more involves the performance in relation to WOW.
currently the headset is plugged in to the optic port on my z77 sabertooth 7.1 onboard sound. I think it sounds great, but I have the Xonar DX from my last system I could use
http://www.bestbuy.com/site/Asus+-+Xonar+DX+PCI+Express+Sound+Card/2963455.p?id=1218690824418&skuid=2963455&sellerId=#tab=overview
My question has TWO part so please answer them both if you can.
1. Would using the Xonar DX produce better sound? (the headset sounds fantastic via onboard/optic output, but if it can get better I would like to know)
2. Does using onboard sound like on my mobo cause a heavy resource drain that could affect performance in WOW? (I have moments in 25 man raids where I get a strange lag effect, I see spells casting noticeably late after having executed them via keybinds, this tends to only happen for a few seconds here and there and when lots of different fight mechanics are taking place including large visual impacting effects by other players like aoe. I was wondering if the sound processing onboard could be adding to this lag effect)
3570k @ 4.5Ghz
sabertooth z77
