Onboard sound vs my old sound card
11wow11
5
Well my computer is currently sitting on my table in pieces. I was gutting my old computer debating on which parts to trash or keep. I have my old Creative Sound Blaster Audigy SE 7.1 Channels 24-bit 96KHz or my motherboards on board sound. motherboard=Z68P-DS3
On board
Realtek ALC889 codec
High Definition Audio
2/4/5.1/7.1-channel
* To configure 7.1-channel audio, you have to use an HD front panel audio module and enable the multi-channel audio feature through the audio driver.
Support for S/PDIF Out
auidgy
Auidgy
Playback: 24-bit Digital-to Analog conversion in 16 or 24-bit with sampling rates of up to 96Khz to analog 5.1 speakers
Recording: 24-bit Analog-to-Digital conversion in 16 or 24-bit with sampling rates of up to 96kHz
SPDIF output with up to 24-bit resolution at selectable sampling rates of 44.1, 48 and 96kHz
Your SB Audigy has the edge over you Realtek onboard but unless your output devices can produce the full frequency that both sound chips are capable of then you won’t be able to tell much of their differences.
