Onboard vidio went bad need info for getting vidio card for pci slot to fix issue
TJMCGRADY
ONBOARD VIDIO WENT BAD. NEED VIDIO CARD FOR PCI SLOT . HAVE GATEWAY DX4720-03 DESKTOP. NEED TO KNOW IF I CAN PUT A VIDIO PCB CARD IN THE PCI SLOT TO REMEDY NO VIDIO PROBLEM....IF SO DO YOU HAVE A PART NUMBER ...THANKS.......TOM ....TJMCGRADY@VERIZON.NET
If this is your PC: http://support.gateway.com/s/PC/DX/DX4720/DX4720sp2.shtml
...it has a PCIe X16 slot which would be preferred for adding a discrete card over PCI. I presume you are not a gamer and just want economical video. Any of these will fit that PCIe X16 slot. Look for one that has the same video port on it that you are using now. VGA, DVI, HDMI...
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007709%20600007852%20600007855%20600007856%20600286742&IsNodeId=1&name=PCI%20Express%203.0%20x16&Order=PRICE
