Question One Cable, two signals monitor help.
Dec 8, 2019
4
I am wanting to display 2 different things on both a tv and a vr headset, using one HDMI cord from my computer. I thought I could either do this by starting as one HDMI and use the bandwidth to run two separate 2k or 1080p signals, and use a splitter somewhere along the line to supply two different monitor inputs, and if the hardware didn't allow that to be possible input wise, I could use an HDMI combiner to combine to separate outputs from my computer, and then from one cable, run it to the splitter. I can't find anything to do this, and I can't afford to run another 50ft of HDMI to take up space.
Dec 8, 2019
4
HDMI doesn't support multiple independent displays from a single port.
Thanks for your response. I'm kind of surprised yet I kind of thought this might be the case. Since I don't want to use another hdmi or an expensive hdmi to ethernet extender, do you have any other cheap suggestions? I am trying to run 50ft.
