D dylan_frost Feb 14, 2018 2 0 10 Feb 14, 2018 #1 https://gyazo.com/de6d656cf006b47a499e0c58fb4cd72a Is this a normal thing to happen?
Solution zoltan.boese Feb 14, 2018 Yes, most on the time you use only one of the cores. Also http://www.tomshardware.co.uk/forum/id-1800828/intel-temperature-guide.html
zoltan.boese Estimable Jan 30, 2018 1,550 0 2,960 Feb 14, 2018 Solution #2 Yes, most on the time you use only one of the cores. Also http://www.tomshardware.co.uk/forum/id-1800828/intel-temperature-guide.html Upvote 0 Downvote Solution
D dylan_frost Feb 14, 2018 2 0 10 Feb 14, 2018 #3 zoltan.boese : Yes, most on the time you use only one of the cores. Also http://www.tomshardware.co.uk/forum/id-1800828/intel-temperature-guide.html Thank you. Upvote 0 Downvote
Dragos Manea Splendid Mar 30, 2015 2,716 161 22,790 Feb 14, 2018 #4 It is normal to be higher but your cpu is overheating, cpu cores should not get near 100 degrees, it is recomended 60-70 and acceptable 70-80 but never 90 or 100. Upvote 0 Downvote
