one of two hard disk having extremely low write/read speed
Pratik Sonawane
5
one of my hadrd disk having extremely low read/write speed ( variable 400 kbps - 1 mbps ) . 2 gb folder took 57 minutes to copy . i need to transfer data into new hard disk , but these speeds are driving me crazy . ..... please help me
(chkdsk/xcopy/xxcopy/robocpy didn't work perfectly)
I had similar issue.. ran the drive manufacurers test tool on it.. which confirmed it was on its way out.
So do the test.. and if the same for you.. get your stuff of it ASAFP before it gives up completely.
and if you say "chkdsk didn't work perfectly".. It suggests even more strongly that drive is going bad.
Cheers
hmmm it shows ( problem 008 - too many bad sector ) after more than one hour of scanning .... called WD for replacement ....... but i need to recover files somehow before sending it.please help me .
smartctl 5.43 2012-06-30 r3573 [i686-w64-mingw32-win7-sp1] (sf-5.43-1)
Copyright (C) 2002-12 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF INFORMATION SECTION ===
Model Family: Western Digital Caviar Green (Adv. Format)
Device Model: WDC WD10EARS-00Y5B1
Serial Number: [No Information Found]
Firmware Version: 80.0
Device is: In smartctl database [for details use: -P show]
ATA Version is: [No Information Found]
ATA Standard is: [No Information Found]
Local Time is: Mon Jul 22 10:06:44 2013 IST
SMART support is: Available - device has SMART capability.
Enabled status cached by OS, trying SMART RETURN STATUS cmd.
SMART support is: Enabled
Error SMART Thresholds Read failed: Function not implemented
Smartctl: SMART Read Thresholds failed.
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x84) Offline data collection activity
was suspended by an interrupting command from host.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (18960) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
No General Purpose Logging support.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 219) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 196 196 --- Pre-fail Always - 37191
3 Spin_Up_Time 0x0027 129 121 --- Pre-fail Always - 6533
4 Start_Stop_Count 0x0032 092 092 --- Old_age Always - 8140
5 Reallocated_Sector_Ct 0x0033 200 200 --- Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 --- Old_age Always - 0
9 Power_On_Hours 0x0032 081 081 --- Old_age Always - 13924
10 Spin_Retry_Count 0x0032 100 100 --- Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 --- Old_age Always - 0
12 Power_Cycle_Count 0x0032 092 092 --- Old_age Always - 8084
192 Power-Off_Retract_Count 0x0032 190 190 --- Old_age Always - 7810
193 Load_Cycle_Count 0x0032 193 193 --- Old_age Always - 21658
194 Temperature_Celsius 0x0022 107 098 --- Old_age Always - 40
196 Reallocated_Event_Count 0x0032 200 200 --- Old_age Always - 0
197 Current_Pending_Sector 0x0032 192 192 --- Old_age Always - 1378
198 Offline_Uncorrectable 0x0030 200 194 --- Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 --- Old_age Always - 3
200 Multi_Zone_Error_Rate 0x0008 200 143 --- Old_age Offline - 67
Error SMART Error Log Read failed: Function not implemented
Smartctl: SMART Error Log Read Failed
Error SMART Error Self-Test Log Read failed: Function not implemented
Smartctl: SMART Self Test Log Read Failed
Error SMART Read Selective Self-Test Log failed: Function not implemented
Smartctl: SMART Selective Self Test Log Read Failed
