One piece of my hardware is causing lag help pls
Hazza462
13
Hi guys,
(My PC Specs are at the bottom of this post)
Recently I have been lagging (fps wise) on games due to a hardware fault on my system somewhere. I have been trying to work out which part is causing the problem but I am having no luck whatsoever. I deduced that my problem was my hard drive eventually due to it making clunking sounds and crashing/freezing my computer multiple times. I have now replaced this and re-installed Windows. The first day after I installed it none of my games had any trouble running on the settings I was used to running them on before the lag occurred. However, as I went to load up a game today (Counter Strike: GO) the lag returned 🙁. I think this confirms that it is a hardware issue because of the fresh install of Windows and drivers, and of course the new hard drive, that rules that out. Please help me if you have any suggestions... 🙁
Intel i5 4690K @ 3.5GHz w/ Hyper 212 Cooler
NVIDIA GeForce GTX 650Ti
Kingston HyperX Beast RAM 8GB
GIGABYTE 400W Power Supply
Seagate ST1000DX001 3.5 inch 1TB SSHD
Windows 8.1 Pro 64 Bit
Go tothe cmd prompt and type chksdk /f /r . Then sit back and relax for couple of hours or the whole day ehile your system checks your hdd for any bad sectors and will try to fix it.
