[SOLVED] One screw won't go into case fan
CosmicNinja
17
I recently got 2 case fans. One for intake, one for exhaust. Both work fine, but the intake one has a dodgy screw hole on the bottom right. It goes in, but it doesn't screw in tightly like it should. The other holes are fine though. Does this matter or should it be fine? Tried testing by trying to shimmy it while it was screwed in and it felt solid enough.
It's a case fan. Many don't even use screws but little rubber or plastic pushpins, zipties and other such means of attachment. You can even just use 2x opposing screws and be fine for support.
