Hi, I bought a custom built pc 2 years ago, and about a year ago my cpu started overheating (running at 53c idle) i used speedfan and checked in bios (in bios it would lower by a couple of degrees), so I asked a friend to replace the stock cooler (I'm too nervous to handle anything near cpu), it then started running at about 30c, I also fitted an extra fan into 5 1/2" drivebay. Pc was fine until now when its overheating again - I'm running it with side off now and core is 42c idle but starts going into 50's as soon as I'm doing anything other than email or web browsing. I came here cos I've seen all great advice when trying to learn more about pc's. Here are my specs:
Thermaltake Toughpower 700w psu (bought and fitted after overheat started, i know its not the best but i was on a budget)
asus M2V-TVM motherboard
Athlon 64x2 3800+ cpu (not sure which revision cos voltage on mine is 1.15v and none on amd site list that voltage):
http://products.amd.com/en-us/desktopcpuresult.aspx?f1=AMD+Athlon%E2%84%A2+X2+Dual-Core&f2=3800%2b&f3=2000&f4=512&f5=AM2&f6=F2&f7=90nm+SOI&f8=&f9=2000&f10=False&f11=False#
Thermaltake Silent 939 K8 Heatsink
2 gb ddr2 ram
ATI Sapphire Radeon 4870 512mb (bought and fitted after overheat started)
2 sata hdd
sony dvd rw (not lightscribe)
Card reader/floppy drive
and up to 4 usb devices
1 x 2000rpm intake fan 1 x 2000rpm exhaust fan 1x 2000rpm 5 1/2" drive bay fan
any advice would be greatly appreciated and I can provide more info if wanted, thanks in advance.
2 gb ddr2 ram
2 sata hdd
