Hey all,
Looking for help identifying the root cause of a persistent stability issue with my newly built system. I want to outline everything from the beginning in case anyone has experienced something similar or has insight into what could be going on.
System Overview:
Initial Setup & Boot Issue:
Has anyone else experienced this type of behavior? Or seen similar reports tied to this generation of Intel CPUs or Z890 motherboards — especially MSI’s GODLIKE? Any links, threads, or firsthand experience would be super appreciated.
TL;DR:
System Overview:
- Motherboard: MSI MEG Z890 GODLIKE
- CPU: Intel Core Ultra 9 285K
- GPU: MSI RTX 5080
- RAM: DDR5 7200 (XMP used intermittently during testing)
- PSU: MSI MPG A1000GS PCIe 5.0 (ATX 3.1)
- Cooling: TRYX Panorama SE 360 AIO
- OS: Windows 11 (Fresh install after initial issues)
- After upgrading to this platform, I couldn’t get into Windows due to Ethernet driver issues. I got impatient and nuked the system with a fresh install. Despite that, I still had to manually download and install LAN drivers on another PC to get back online.
- UserBenchmark tests ran extremely laggy — delayed sound, choppy visuals, 5–10 second input lag.
- Boot times were slower than expected (especially compared to older systems using the same SSD).
- Some benchmarks (like Time Spy and Civ VII) caused hard crashes, not BSODs — just full system lockups with AIO screen resetting, but system still powered. No keyboard/mouse response.
- Updated to the latest BIOS (v1A1) to address potential Arrow Lake microcode and firmware issues.
- Disabled XMP and saw some perceived improvement, but still experienced crashes under certain loads (3DMark CPU Profile, Time Spy, games).
- Re-enabled XMP and ran multiple benchmarks. Some completed successfully (Steel Nomad, Speed Way), but crashes eventually returned — same freezing behavior, same reset symptoms.
- Enabled Fast Boot and Memory Fast Boot (post-BIOS update) — boot time improved noticeably.
- Plan to begin structured testing using HWiNFO64 logging + benchmark loops to pinpoint the failure point.
- Testing will involve running multiple benchmark passes with XMP disabled, logging all sensor data to verify if RAM is at fault, or if the root issue lies elsewhere.
TL;DR:
- Z890 GODLIKE + Ultra 9 285K system
- Initial post-install required manual LAN drivers to reach internet
- UserBenchmark + general use was laggy even at stock settings
- Multiple hard crashes in Time Spy/Civ VII
- Tried disabling/enabling XMP, improved boot time with fast boot, but crashes persisted
- BIOS updated to latest (v1A1)
- Currently planning detailed testing with HWiNFO logs to isolate root cause
- Goal is to confirm if it’s BIOS/firmware-related or true hardware failure
