Onkyo receiver ac cable
Brevcent21
9
I have an Onkyo TX 8020 audio receiver that has a power cable built into the unit so it’s not one you can just buy from the store. My dog chewed through it so I’m trying to find a replacement but have been unable to find one. I opened it up and the part that plugs into the board is a white two pronged plug. I can post pictures if needed.
Thank you guys in advance! I’m not wanting to drop money on a new one it’s a great device.
I don't think you can find a ready replacement cable with that connector attached. What you can do, however, is to get another two-wire cable with open end, cut the chewed cable like four inches / ten centimeters away from the connector, and splice the cables using some wire connectors like these. Keep the splice inside the unit, and find a way to immobilize it at the entry.
