Ooops!! Always remember to turn on your water pump!!!
james_p
8
One problem with having an external water pump, if you ever turn it off, remember to turn it back on before you turn your PC on. Or else you get to watch your temps rise until the PC turns off while you scratch your big dumn head (that's me in this example). "OH YEAH!" and I turn the pump on.
Thankfully no damage done.
BTW, that above example is what happened with my Zalman water/cooling/pump tower. It runs quiet, but so quiet you don't know if it's on or off.
I'm thinking it should be wired to the PC somehow so when the PC boots up or shuts down so would the pump.
Or maybe never turn it off?
http://overclockers.com/tips220/ <---This guys unfortunate pump disaster... but amazingly the cpu still works? .. with brain damage possibly?
Don't need to tell me about that. looks at this... my ol' A64 3500+ CPU.
You can use an AC hermaphrodite connector. It sits between the wall plug and the power supply socket. Standard on my waterchill controller. Turns the pump on as soon as the pc power supply starts drawing power.
simply avoid the problem by not using a pump that does not power on the PSUs 12v output, otherwise you are bound to have it coming soon! if not from your own mistake....... it will be someone elses.
ElMoIsEviL, give us some details bout that.
It seems cpus are great now for picking up the hsf is removed, but not smart enough to detect a slow heat raise, as for the A64 - makes me wonder what a prescott will do.
use your head sir!!
Thermal throttle and finally shutdown, the newer pentiums not only tolerate higher temps but also have a safety mechanism to shutdon/crash when overexceeded , thereby saving other components.
use your head sir!!
"This is a Northwood with the heat blisters. And it did shut itself off. I just had no idea it would get hot enough to cause minor burns to the plastic before it shut down." - crashman himself said it
i miss the days of the old K6-2s... i hat a 550 OCed to 650 and i remember coming home to find that i didn’t secure the heat sink... it was dangling by the power wires.. and yet the machine was still running.. i of course immediately shut it off.. stupid me i touched the processor only to burn myself pretty badly... but i was surprised that no problems resulted.. i still have the processor and i think it still works... they were built well in those days.. then the athlons came along.. freaking things fried if you farted in their general direction...
celeron 550? no such thing, but the celeron 566'ers overclocked nicely, as did any coppermine (aslong as they werent over the 1ghz range).
AMD got there bad name cause there chips were concidered hot (altho now some prescotts are twice the heat of any K7) and had no thermal protection incase bad things happend (dust, hsf falling off, failing fans etc) - they wernt a bad chip if you looked after em tho (checked for dust every once in a while, decent cooler and airflow).
