Rain_3 :
Gnuffi :
Rain_3 :
So now I'm wondering if I should just have 3 intakes, because it is open air eventually all the hot air will dissipate through the front and all.
thats just not how thermals work
and by the looks of it that case would prob be one of the worst cooling solution cases out there
in order to rectify some of the blunders made cooling solution wise you need to think alternatively
A
either you go with a full on negative pressure case, all fans/rads exhaust, which i suppose might give teh best cooling in that case design
B
or you let the rear/+roof/top back fan intake and the roof/top front fan exhaust and leave the middle fan alone (dont have intake and exhaust in close proximity )
C
or you take the the rear/+roof/top back fan exhaust and the roof/top front fan intake and leave the middle fan alone
D
or roof/top middle+front fans intake and rear exhaust, leaving the roof/top back fan alone, again to not have intake and exhaust too close proximity
i think A would work the best in that case
next would be B then D.
Option C would probably result in the worst internal air flow of the 4
I was initially going to go with A, but then my friends told me positive pressure works wonders also. So I thought 3 intakes would create positive pressure. Is negative pressure better than positive in an open air case?
the reason positive pressure works wonders is its less demanding on cleaning
since negative pressure is gonna require you to clean your PC often due to dust, and a positive pressure can cool quite efficient, but greatly reduces the "demanded" amount of cleaning
in terms of cooling true negative pressure will cool slightly better than positive pressure, but the difference is not huge enough, for non enthusiast to concern about it
only reason negative pressure (option A) is considered for your case, is it has such poor cooling options, it almost suddenly becomes the only "true" viable
since all your case fans are top mounted, even as intake, you will have bad air pockets, stale air, limited non-optimal air flow
had you had atleast 1 bottom fan beneath the mobo, or atleast 1 side vent in a lower GPU position it would instantly be better, but your case doesnt, which means you wont have any "optimal" way of moving air into your case without interfering with the flow and "rising heat"
imagine it like so,
you place your roof/top fans as intake, yes you introduce some "fresh" air into your case, but since heat rises, all you do is push the hot air back down, making it "tumble" round inside the case, it wont be automatically directed to the front where it can freely escape, because it will naturally keep trying to rise up and you have no "forward" airflow momentum
and should you take the rear as intake while still having a top intake in the top front/middle,
the heat will rise up, be pushed in direction of the front, but the top intake will push it back down, and the automatic turbulence form the rear intake will cause it to cycle back down to the left and up again , never "truly" reaching the front and venting
and should we take the rear as intake and the roof as exhaust you do get some air flow, but very limited the entire lower part of your case will only get passive airflow from the turbulence created in eh top,and vice versa if top middle/front is intake and rear exhaust
where as if you mount all fans as exhaust and go for true negative pressure, the negative pressure will suck in air from the "open" front and give some flow, however minor
all in all, while the case looks amazing, it has some extremely poor thought out cooling solutions, since you will lack flow in some parts/get dead air pockets, no matter which of the solutions you chose, and only options is to limit them however little is possible and the negative pressure would be the "best of the worst" in that case scenario..
