Open Hardware Monitor?
StreamingGames
102
What is a good program to hse to monitor my temp and everything? Someone suggested Open Hardware Monitor. Does anyone have any experience with it or a different program? Please let me know the pros and cons of whatever you suggest. Thanks!
I've used Open Hardware Monitor, it's open sourced (not regularly updated though), has almost the same sensors like HWmonitor, in addition it has a Tray icon, always on top customizable desktop gadget, graph plot, can hide sensors, set fan RPM manually, logging and remote.
Although when testing system temps I prefer using Hwmonitor and RealTemp :)
Ah okay thank you! And while I have you here maybe you could help with this.. I wanted to see my temps because I think something is wrong.. whenever Im gaming my computer starts to pulsate.. its on my desk and it feel like my phone is vibrating.. idk what it could be.. nothing seems to be loose.. is that normal? (Just built it my first build so idk..) i have an evga 750w 80 gold zotac gtx 980 Noctua nh-d 15 msi z170a gaming m7 i7 6700k and the stock fans with the fractal design define xl r2. It only happens when Im gaming..
Im not able to tell whats vibrating. I dont know what it could be. Im very nervous because Ive spent a TON of money on this build and I dont think its normal for it to do that.. the only things I could think are maybe its the graphics card since it only happens when Im gaming?
