Have a few questions this will be my first shot at this so i will be asking quite a few questions.
1. Is it possible once I figure out where everything is going and length of tube to put everything together outside of the case and then start the pump fill it and let it sit setup running for a day to make sure there’s no leaks? Like a test run if you will or even for an hour?
2. I would like to use only the best parts. What are the best fittings, best pump, best resivoir, best clear tubing so I can have a green liquid cooling,
Best cooling liquid or is distilled with a few drops of dye the best. Really interested in this question. Money will not be an issue for this part of the build but I also know the most expensive parts are not necessarily the best.
3. Any hints tips or you tube videoes I should watch. Any threads I should read. A webpage deciated to liquid cooling. Also any tips or warnings from anything you have learned from trial and error.
I will be taking my time and doing this slowly and carefully really appreciate any and all info on this subject I don’t want to make any mistakes.
Thanks
Thanks
