Operating system not found
Maxkelly
4
Hello,
I have fujitsu siemens amilo Pi 2530 windows vista.Unfortunately my computer is showing OPERATION SYSTEM NOT FOUND when switched on.And I get the following message when trying to boot it.
The installation was canceled,windows cannot open the required file D:/Sources/install.wim.The file does not exist,make sure all files required for installation are available and restart the installation,error code 0x80070002.
The error you receive is normally associated with the Installation of Windows error, or a Windows update error. Did anything unusual precede receiving this error, or did you have a normal shutdown, but the computer simply will not startup ? Take a look at the Vista Recovery options, which may help you.
http://windows.microsoft.com/en-US/windows-vista/What-are-the-system-recovery-options-in-Windows-Vista
