Question Opinion on case, cable management etc
Looks count.
A case tends to be relevant for a long time.
I like the ability to have two 140mm front air intakes.
Such fans will give you all the cooling intake you might need.
I do not see mention of washable front filters which will keep your parts cleaner.
A second negative to me is the 155mm height limitation if you will use air cooling.
160mm is needed for the best air coolers.
I am not a fan of aio coolers unless you have no other option.
What components will you have inside?
You may not need maximum cpu cooling.
Do you need a dvd drive?
I never worry much about cable management.
Looks count.
No I dont need a dvd drive I will be using 4 fans for cooling probably and the cpu cooler already comes with the box of the ryzen 5 1600 AF
About extra components I might put a SSD
Looks count.
If I add 3 120mm fans ( 2 in the front and one on the top would it be fine ?
Latest posts
