Question Opinion on temps for a Ryzen 7 2700
Dec 24, 2019
18
Hi, merry christmas.
My Ryzen 7 2700 (non-x) gets up to 75,5 degrees according to HWmonitor, Hwinfo*, while OC'd @ 4,1 GHz, 1,35 volts. It is paired with a Cooler Master 212 EVO.
Although well within specs, it is a bit too high for my liking, and I was wondering if this is a fine temp range for extended use .I plan on keeping the chip for as long as it can keep up with the newest games, so I obviously want it to live for as long as possible...
Reactions: 2700ksj
It's a Ryzen. Not an intel. If you are conditioned to Intel temp scales, then it's going to leave you in a panic.
At idle, Intels will drop frequency and corresponding voltages across all the cores, which remain active, so any windows or background tasks are split up between them. This'll show as 30's taking spikes to 50ish at times.
Ryzens work differently. A Ryzen cpu will shutdown partial or full cores entirely, leaving only 1 or 2 active, which have the full idle workload on them, so tend to stay in the 40-50ish range on average.
Core/thread counts also have fun with load temps, a 6/12 stands a good chance of running a little warmer when more than 6 threads are used vrs a 6/6, even with a more efficient nm process.
All of the temp software is accurate, as far as reading a sensor goes, the issue is in polling times. If a load goes from 30 to 40 to 50 to 30 at idle in 1 second, and 2 software poll at 350ms and 700ms, then what you get is one software reporting a temp of 40, the other a temp of 50. Considering software only shows temps every 2-3 seconds (any faster and it'd be a digital 88 blur) you end up with a temp being reported for nothing. Ryzen master averages the last 3 polls, so reports the average, not a specific.
Reactions: CountMike
