Question Opinions and Advice on my pre-built!
billiingtons11
40
Operating System: Windows 11 Home
Gaming Chassis: CORSAIR ICUE 4000X RGB SERIES ATX Mid-Tower Gaming Chassis + AirGuide RGB fans (Black)
CPU: Intel® Core™ Processor i7-13700K 8P/16 + 8E 3.40GHz [Turbo 5.4GHz] 30MB Cache LGA1700
CPU / Processor Cooling Fan: Corsair iCUE H100i RGB ELITE 240mm Liquid CPU Cooling System w/ Copper Cold Plate
Video Card: ASUS TUF Gaming NVIDIA GeForce RTX™ 4070 Edition Gaming 12GB OC GDDR6X Video Card (DLSS 3.0) [AI-Powered Graphics] (Single Card)
Power Supply: 850Watts - Corsair RM850x SHIFT 80 PLUS Gold ATX 3.0 Fully Modular w/ PCIE 12+4Pins Connector for PCIe 5.0 graphics cards
Motherboard: MSI PRO Z790-P WIFI DDR5 ATX w/ Wi-Fi 6E, 2.5GbT LAN, (3)PCIe x16,(1)PCIe x1, (4)M.2, (6)SATA
RAM / System Memory: 32GB (16GBx2) DDR5/6000MHz Dual Channel Memory (Team T-FORCE DELTA RGB)
Primary Hard Drive: 2TB WD Blue SN580 Series (PCIe Gen4) NVMe M.2 SSD - Seq R/W: Up to 4150/4150 MB/s, Rnd R/W up to 600/750k (Single Drive)
Hey everyone, I built this PC through CyberpowerPC's and I just wanted to get opinions and advice on it. If there is anything I should change, please let me know!
In regard to the MOBO, I was going to go ASUS, but I've learned recently that there have been issues with them and burning out CPU's so I'm hoping MSI should be a good decision here. I also wanted to make sure that 850W will be good enough for this system as well. In regard to the GPU should I go with the TUF 4070 or the founder's edition? I know ASUS has been in some shaky waters recently and just wanted to gather some opinions on this. Finally, I decided to go intel over the Ryzen 7 78003DX as I have seen that the SOC voltage is messed up and I don't really want to deal with that issue, even if it does perform better and uses less power.
I would love honest opinions and advice no matter what they are, thanks in advance!
Specs wise, it's fine...though you're forgetting a critical aspect of your build. That would be, how much are you spending on the build listed above?
If it's possible, can you pass on a link to the build you've spec'd on Cyberpower PC's? You could look into a higher pedigree board from MSI or Gigabyte. As for AMD's platform, so long as you're on the latest BIOS version, you should be alright with the SoC voltage issue.
http://www.cyberpowerpc.com/saved/1R8K3P Here is the link!
I appreciate the response. Thats good to know I just wasn't sure if it was fixed for sure or not, but honestly at this point I think I'm going to stick with intel for the time being as it has always treated me well. But let me know what you think of the pricing and stuff! Some of the extra charge and stuff is due to the expedited shipping and warranty costs...
@billiingtons11 you can always order the parts and call around to mom & pops PC / laptop repair shops and have them build it for you. This way you know that you're getting a quality build at a reasonable price. Something like this for example.
PCPartPicker Part List
CPU: *Intel Core i7-13700F 2.1 GHz 16-Core Processor ($346.99 @ Amazon)
CPU Cooler: *Deepcool AG620 BK ARGB 67.88 CFM CPU Cooler ($54.99 @ Amazon)
Motherboard: *MSI B760 GAMING PLUS WIFI ATX LGA1700 Motherboard ($159.99 @ Amazon)
Memory: *G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory ($96.99 @ Newegg)
Storage: *Crucial P5 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($109.99 @ Amazon)
Video Card: *MSI GAMING X TRIO GeForce RTX 4070 Ti 12 GB Video Card ($799.99 @ Amazon)
Case: *Lian Li LANCOOL 216 ATX Mid Tower Case ($104.99 @ Adorama)
Power Supply: *MSI MPG A850G PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($129.99 @ Amazon)
Operating System: *Microsoft Windows 11 Home OEM - DVD 64-bit ($121.98 @ Other World Computing)
Total: $1925.90
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2023-10-03 03:54 EDT-0400
A better look at those components.
https://www.msi.com/Motherboard/B760-GAMING-PLUS-WIFI
https://www.intel.com/content/www/u...-30m-cache-up-to-5-20-ghz/specifications.html
https://www.deepcool.com/products/C...al-Tower-CPU-Cooler-1700-AM5/2022/16082.shtml
https://www.crucial.com/products/ssd/crucial-p5-plus-ssd
https://www.msi.com/Graphics-Card/GeForce-RTX-4070-Ti-GAMING-X-TRIO-12G
https://www.msi.com/Power-Supply/MPG-A850G-PCIE5
Total: $1925.90
That’s a good point. At this point I’m planning on going through microcenter and getting them to build a PC for me. Im fine with their fee and Ill be able to get all that I want. I agree with you there. Id like to be able to completely choose what I get and I think this is the best way. I appreciate the build as well! But Im pretty set on what I have currently so I think Ill stick with that through Microcenter. Thank you for the response as well!
Reactions: Why_Me
