Hi,
Long time reader, first time writer.
I'm planning my first rig, but I'm worried about cooling.
I have put myself a budget of $2,500 to $3,000 USD and this what I have come up with (you're welcome to comment on it):
[strike]https://pcpartpicker.com/list/cGKPD8[/strike]
[strike]https://pcpartpicker.com/list/JMQyr7[/strike]
[strike]https://pcpartpicker.com/list/W8mF9W[/strike]
https://pcpartpicker.com/list/kwm6gL
My idea is to build a nice, classy rig, which is a powerhouse for gaming. The classiness being provided by the Phanteks case, and the powerhouse coming from the 1080 Ti and just using SSD's.
So here is my worry: cooling.
First off, I would have liked to go with the i7-7700k, but I've read it has had some temperature issues, so I have opted for the i7-6700k. Not THAT big of a difference for gaming, and cheaper. I wanted a LGA 2011 CPU, since I'm aiming to use DDR4 (power, again). So in terms of cooling, this CPU seemed like a good balance between power and temperature. Am I correct here? Am I missing something?
Second, the i7-6700k is still quite hot, and the Strix variation of the 1080 Ti will be an important source of heat inside the case. Fortunately, the Strix has headers for external fans, so I could probably hook them up to some case fans for automatic control. In addition, the Phanteks Enthoo EVOLV ATX case has been praised time and again for its ease of use and aesthetics (right on cue with what I want). However, doubts have been raised about how well the top part of the case is at being used as an exhaust since hot air coming from inside the case can bounce back in. So all of this begs the question of fan and radiator placement inside this case. Here are some ideas that have come to mind:
(a) Put three 120 mm fans in the top so that air has no way to go but out through the vents, and a 140 mm fan in the rear to seal the deal. However, that's a lot of air coming out of the case, and I want to have either neutral or a bit-positive pressure inside the case (to avoid dust build up). I'm thinking of maybe putting the H100 radiator in the front as in-take with a push/pull configuration (so to keep a good amount of air flow coming into the case through the radiator), with an additional 120mm fan in the bottom-front part of the case. This idea has a LOT of fans, and I'm not sure it would provide positive pressure.
(b) Same idea as (a), but no 140 mm rear fan. This could be enough to provide near-balanced air pressure inside the case, but the empty back grill will be kind of an eye-soar.
(c) Put the radiator in the top as an exhaust in a pull configuration, with an additional 120 mm fan to avoid that hot air bouncing back in, a 140 mm in the rear, and three 120 mm in the front. Since the static pressure of the radiator lowers the air flow considerably, I think this could be close to balanced. However, I'm not sure I'm comfortable with the radiator sucking in the hot air being blown out from the Strix 1080 Ti.
And there it is... sorry for the long post. I've been thinking about this for a long while, and can't seem to arrive at a solution.
BTW, I'm open to any type of change to my build (even changing the case, if need be).
Cheers.
EDIT 2017-05-18: Some changes have been made to the build, so I've crossed out the old link (which still works, if you want to compare them) and I added a new link that points to the revised build.
EDIT 2017-05-19: Yet more changes were made. Thanks to Isokolon for all the help. I think we are almost there.
EDIT 2017-05-26: Finally convinced on the i7-7700k. Thanks everybody who contributed, but specifically to Isokolon for all the great tips. I think we have a seriously good build here. Now, to convince the wife. C'yall.
Cheers.
