Build: https://au.pcpartpicker.com/list/VPMCLJ
I do have a couple of questions:
1) Is it true that overclocking does reduce the lifespan of your cpu, but by that time your cpu be obsolete anyway?
2) I plan on overclocking to at least 4.8ghz minimum. Will the new Dark Rock 4 be able to achieve this?. Or would it be a safer bet to go with the beefier Dark Rock Pro 4?
3) Should I keep the system at stock until I need the overclocking performance or should I overclock straight away?
Thanks!
Thanks!
