G
Guest
Guest
Hi all,
I've been researching this issue, but would like everyone's thoughts on what would make a good aftermarket HSF for my system:
Antec Signature SG-850 PSU (1 80mm fan)
Antec 1200 Case (6 fans) (side panel currently off of system)
Gigabyte GA-MA790FX-UDP5 Mobo
AMD Phenom II X955 BE @ 3.2ghz (stock HSF, no OC)
Patriot Memory 4 x 2gb @ 1600mhz
ATI HD4890 x 2 @ OC to 940/1140mhz (stock cooling)
Seagate 1TB 7200.12
APC Backup-UPS XS1500
LG DVD/CD RW
Currently my CPU runs around 40-42 @ idle and up to 55 @ load.
My GPU's run around 61-65 @ idle and up to almost 90 @ load.
- What HSF do you use
- What kind of temp improvements did you see
- Where did you buy your HSF
- I've heard that perfect flatness ot the HSF base is preferred. Thoughts
I really appreciate everyone thoughts and time. Thank you!
John
Comer, GA
Seagate 1TB 7200.12
LG DVD/CD RW
John
Comer, GA
