Question Opinions on fan layout for meshify c
uz3390
20
Hi,
I intend to get the fractal meshify c mini and a 5 pack of arctic p12 fans (https://www.amazon.com/ARCTIC-ACFAN00137A-Value-Pack-Pressure-Optimized/dp/B07HC782D5), from my brief research on case thermals i have decided to use for 4 fans as intake (3 in front 1 on the bottom ) and 2 for exhaust (stock fans). So my questions are, would this create a hot spot near the gpu, would it be better if i went with 140mm fans instead? Also i am looking for the best possible thermals so noise isn't too much of an issue.
uz3390
20
Like i mentioned noise isn't an issue as it will most likely be drowned out by my ceiling fan.
How about from a cooling perspective would 2x140mm fans give me better temps than 3x120mm fans?
Given that a Be Quiet or a Noctua fan costs ~$20 that will cost me $80 for 4 fans as opposed to the $30 for the 5 from Arctic, besides I've mostly read good things about them
uz3390
20
Actually my main concern is about gpu temps, that is if i add a fan as a bottom intake would that push air away from the gpu? If i added 140mm fans would they feed more air to the gpu?
