Opinions on this build and how to cut it down a bit
remove the hard drive....use an m2 or mve ssd as the boot os then add hard drive when you have the funds. if your close to a micro center look at there cpu and mb combo deals. drop down to a locked i5 and non z mb. go with seasonic bronze not gold power supply.
I live in New Zealand, there are no good place to buy so i have to order from newegg and go to some physical stores in NW and I do plan on overclocking
the h7 is not going to be enough if you plan to overclock
you need the h5 ultimate or h5 universal
minimum
what you can do is drop down to a 550w power supply
get a cheaper case
drop the small ssd
and drop down to a gtx 1070 ti
to cut costs a bit
