Opinions on VGA- Building PC
Coreman
30
Hi Guys, I'm new to the Forum, so Hello! :)
I got a limited Budget and I'm trying build a <<Gaming>> that can hold me for about 1-2 years ,playing if not all, some of the last games @ 1280x1024 and I don't really care about Details
(Even if they are Lowest, its cool for me as long as i get a decent frame rate)
I currently have :
AMD FX 6300
2GB DDR3 ( LOL )
ASUS M5A78L LE
So, I have searched sooo much, and I got some Options I want to tell u,:
1) ASUS GTX650TI-1GD5
(http://www.newegg.com/Product/Product.aspx?Item=N82E16814121669)
2) GIGABYTE GTX650 TI GV-N65TOC-2GI 2GB DDR5
(http://www.newegg.com/Product/Product.aspx?Item=N82E16814125446)
3) MSI R7770-PMD1GD5 Radeon HD 7770 GHz Edition 1GB 128-bit GDDR5
(Used Condition with 3 yrs Quarantee)
(http://www.newegg.com/Product/Product.aspx?Item=N82E16814127687)
(4gb 1333 mhz)
http://www.buzzillions.com/reviews/corsair-cmv4gx3m1a1333c9-4gb-ddr3-ram-reviews#readReviews
(Gaming mouse xD, mine kinda sux)
http://www.trust.com/products/product.aspx?artnr=18307
Which one do you think i should do??
I Know the first 2 cards are WAY better than the 7770 , but I will get them for double price , new ofc.
Dont ONLY judge about the memmory, I will buy a 4gb one, but a month or two later.
Due to power supply, and restricted market, plz just pick one of those options ^^
THANKS IN ADVNACE, :)
yeah... of the cards you listed the 7790 is the best card.
and while max paine might use more then 1gb of vram, those cards aren't fast enough to actually be bottlenecked by having less then 2gb of vram. multiple gpu benches pretty much lock that one up... in games which use more then 1gb of vram, and gpu slower then a 660 or 7870 won't be fast enough for that lack of vram to actually bottleneck it. seriously there is no loss in fps because they aren't fast enough for it to matter.
The only reason to spend cash on more then 1gb of vram...
the 7770 isn't WAY worse then the 650ti... the 650ti are like 10-15% faster then the 7770GE. and not worth x2 the money. No gpu slower then a 660 or 7870 really needs more then 1gb of vram. So you can eliminate the 650ti 2gb from the list. if you want to spend x2 the cash of the 7770GE, i'd get a 7850 or 650ti BOOST... 1gb of ram is enough for either; they're both so close in performance i'd just get whichever is cheaper.
Aeronautics
251
i would disagree to that. Max payne 3 uses more than 1gb of VRAM even on that resolution
The only reason to spend cash on more then 1gb of vram on a gpu slower then the 7870 or 660, is if you plan to SLi or xfire those cards in the future.
