Hi there everyone,
I was waiting for the Amd's Ryzen Launch and now that' already done I was wondering if you all can suggest me a CPU according to my work/requirements.
Currently my setup I'm planning to get
CPU : Ryzen 3900x / i9 9900k
Mobo : x570 / z390
CPU Cooler : Looking for suggestions as well. (Liquid Cooling)
Ram : Trident Z RGB 16 GB 3200
SSD : Samsung M.2 512 GB
GPU : RTX 2070 Super
SMPS : Corsair 1000 W
Alright my main priority is doing mostly Adobe stuffs like (Ae,Ps,Ai,Pr) also I plan to do gaming at 1440p at 144hz. (Not at all planning to go 4K not interested) So according to you all what you think is best for me ? I also plan to get 3 monitor setups as well but i will mostly play with one monitor tho.(middle one)
I would be really appreciated if you can give suggestions and explain why you're suggesting the said cpu.
If I end up buying Ryzen 3900x can I OC it to 5 Ghz or its too much to ask ?
Thanks
Mobo : x570 / z390
Thanks
