On one side of the power supply there should be a table showing max Amps available on the various different voltage rails ... can you look and tell us how many Amps are available on the 12volt rail?
If you choose to upgrade the graphics card in the future, you may need to consider a better power supply (depending on how power hungry the new card is).
