optimal case fan placement
cypfrinide
155
4
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146075&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
thats the case i am going to be getting and i have a few extra bucks so i figured why not load it up with fans but i just want to know what kind of fans to get and where to put them and what not and this is my motherboard idk if that makes a difference or not http://www.newegg.com/Product/Product.aspx?Item=N82E16813130761&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
matt1-0-1
565
126
You'll want to have the fan included with the case at the back, configured as exhaust, and the one you've bought at the front of your case - preferably closest to GPU, configured as intake. Although, if you ever want to add more fans, you can buy a fan controller, or even just buy fans that plug directly into your PSU (although they will run at full speed constantly).
matt1-0-1
565
126
This is the maximum amount of fans you can fit in:
FRONT, 2 X 120mm (optional)
REAR, 1 X 120mm(included)
TOP, 2 X 120/140mm
BOTTOM, 1 x 120mm
If you don't want to fill the whole case, I would strongly recommend putting at least one 120mm fan in the front of the case.
matt1-0-1
565
126
